Cancelled!!! Does anyone have cold weather experience with MT Street R's?
Thread Starter #21
Nope, I was in the beginning stages of R&D and T&T and still in the 10's.
As explained about the the tires the rubber compound is not as elastic, do a burnout, they cool fast while setting up, then launching they don't roll out right and they shock the rear. Think of the shock you would feel if someone threw a snowball down your backside :oops::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO: not going anywhere!;)
Thanks for the info, but my 1Bhp was aimed at Bowlerguy! He's sitting there with a monster and I have been waiting for him to come to the dragway and Land Speed Trials. It's great to have a fast car, but it's even better to document how fast it really is!!! :)
Regardless, he is a good guy! (Though I have never seen him bowl!;))
Bowlerguy92
Needs to warm up before it sees NED. Too cold. I’ve got too much into it now to wall it. :p
Up north here we have taken some impressive cars out in the cold weather. Damn the power difference is noticeable, violent and yes dangerous because the roads are cold. I have done some shit with winter and all season tires. It can be fun but you need to pay very close attention. Not worth it. I have had shit bust loose, I am lucky.
When I go actual is 80-90 and track surface temp is 120, 1,000,000% humidity
But that was 6 yrs. ago
The tire composition actually gets less elastic and more like plastic in cold temps. Generally, it is not recommended to drive them in temps 45 or less. Here’s something I found on the internet
Be warned: because the rubber compound on the drag radials is very sensitive to temperature changes, it's a double-edged sword. You'll enjoy better straight line traction when the air temps are above 60 degrees (F.). But if you decide to drive your car on a cold morning or a cold night, and the air temps are below 50 degrees, you'll find that the drag radials have worse traction than standard radial tires do. If you drive in 40 or 45 degree weather, even with the pavement dry, you step on the gas going into a turn, and find that they spin as though it was raining out.
Even just spirited street driving on a cool crisp spring night..low 50's...needs undivided attention...but it is kinda fun...
I hear he's an ambidextrous bowlero_O;)
It was 55 degrees on an August morning @768’ DA when I ran my best street time with the PS4S’s.:love: Gotta live up here in MN to get those kinds of temps in August. That was a week b4 the Nationals at BIR. That is the kind of air that happens up at that track that pulls the records.
Ha or sometimes a guy gets lucky enough to have morning temps doing laps up there also. Dream time it feels so good. Get the Cup 2R’s warm and they are real sticky.
Thread Starter #28
Street night tomorrow, I much rather do a track rental, but the DA is tempting:
Thread Starter #30
The supercharger loves the cool air. I hope a lot of people show up and keep the track warm!:cool::cool::cool::cool:
I hope the opposite. Many racers means the prep gets worn off, I think. You are the expert here but it seems the fresh track is stickiest.
I have been told by many that I should set up in the darkest tracks that everyone uses. At one busy track rental, I shifted 2' to the left, off the dark lines. I stuck like glue. Next run, a crew in front of me guided their car into the same track I used.
I am still learning...
It'll be fine.
Do a good burnout & SEND IT!!!!!!
Yes, let the track crew help you.
But also, take some time to watch other racers stage and where they line up to the tracks. This will give you some knowledge of your track and how it's working.
@Bowlerguy92 you should go to the track too, you could help each other.
@2ndgen . Your Hellcat is prepared, and you are too! :cool::cool::cool::cool:
Get out and Enjoy All the Fasssst Fun!
~Linda :)
Bowlerguy92
~Linda :)
That's the plan. Unfortunately I can't make it tonight. Next week's weather currently doesn't look great either, so it may not be until the week of the 14th that I can get there.
I wish you guys some future good weather too!
Racing is always better with a friend:cool:
