- #1044
- 6,097
- 30,130
- 352
- Riverside
- CA
- 2015 Dodge Charger Hellcat!
Tools required:
10mm Torx socket.
10mm deep socket.
2 ratchets.
262 Loc-Tite, or Permatex Orange.
In. Oz. torque wrench.
Steel wire brush.
Brembo H-Bobbin hardware kit.
Black Spray Paint (optional)
To begin with, disassemble each rotor, removing the hat, from the disk. You will need both ratchets, with Torx and 10mm deep socket.
My rotors were apparently built on a Friday afternoon. If my hardware configuration looks different, than yours, make a note and re-assemble the way yours are built. That's what I did.
Once the hat is separated, from the disk, you will want to remove the H-bobbins and spring clips. The spring clips slide right out.
I wire brushed the hat and painted it.
While that dried, I took a wire brush, to the H-Bobbins, to remove all the brake dust.
Bob
10mm Torx socket.
10mm deep socket.
2 ratchets.
Steel wire brush.
Bob
- 6
- 3
- 1
- Show All
