Sign Up! To view all forums and unlock additional cool features
I am struggling (only some) on the concept of a 1700 series injector in a Can Am... And is it really the same 1700 series injector that a 6.2L Hellcat motor uses?
The fuel flow is the same but the body is smaller. This is a serious build on this car. Full race engine and huge turbo. I cranked it up to 47 psi and was at 95% on the duty cycle lol. Probably 500 wheel hp.
The ID injectors do very well at lower pulse widths so there were never any idle or part throttle drivability problems. However it did take some work dialing in the 1300s at lower pulse widths where idle and cruise scenarios over lapped to get fuel trims as close as possible to zero.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
