- #1036
- 874
- 2,615
- 182
- Long Island
- NY
- 2017 Challenger HC M6
Spent about half a day working on my cars outside in the 95 degree humid weather. For the Hellcat, changed my rear diff fluid using Amsoil Severe Gear Duty fluid in the bag. That was about the easiest rear fluid change that I've ever done and having the fluid in the bag (not having to breakout the transfer pump) made it super easy.
Had an ABS light pop on the Viper the other week. Didn't have a code reader that did ABS codes, so bought a more expensive one. The scan came back and said it was a fault at the Front, Right ABS sensor. Ordered the part and replaced only to have the ABS sensor remain on. I scanned again and said there were no ABS faults. Light was still on, then tried to erase the code again on the scanner, which once again says there are no ABS faults. The ABS light still remains on. I only drove it a few feet, but the ABS light didn't reset. I'm not sure what to believe...am going to be on the track on Saturday and really enjoy ABS (apparently if there is a fault, the ABS won't work at all). Hoping it resets on the drive to the track; else I'm probably going to have a bad day. Might try to unplug the battery, but then all computer adaptives will reset; perhaps that's a good thing before getting on the track.
- 1
- Show All
