2024 Durango SRT tire wear
Hiawatha
KS
2024 Durango SRT
My 2024 STR alignment was at factory specs on first oil change. The car has 12000 miles and the inside front tires are wearing fast. Are the factory setting correct?
thank you
My 2023 SRT has 17,000 miles and the tires look great. I would say the factory alignment on mine anyway is good. Yours not so much it sounds like.
Yeah, but you also go through curves fast, don't you?
Not with the Durango. It is my high speed super highway cruiser.
Have u had the truck aligned or are u assuming cause it came from the factory the alignment is good? When cars get assembled and transported they often have tweaks in the suspension that needs an alignment.
Its just a camber adjustment and dont assume all alignment shop do the same work. They dont at all! Find a shop that has done countless ones and has experience. Ur alignment sheet should read all green!
thank you
You are adjusting camber on an OEM vehicle? How?
Elementary, my dear Mr. Gatzby. You hit the curbs just right.
