Sign Up! To view all forums and unlock additional cool features
Back in my day they only provided skinnies! Have to wonder if they might be faster, probably no longer legal. Are you allowed to lathe cut the profile of the tires to minimize the contact area?
I’m not sure what rules they have now, been a long times since I was a scout.
I did have to epoxy a steel plate into the bottom to get the weight up. Supposed to be a max 5oz and I’ve got it at 4.95oz
Be careful of ground clearance, the track has (at it least used to) have a raised center and you need to be careful of undercarriage protrusions rubbing the center rail. You are better off drilling holes and adding lead shot and capping with bondo.
Just signed the particular document to send to Mopar to refund my extended warranty. It is substantial and I’ll take it. Tomorrow is the first day after its expiration date. We are mailing it then.
Thanks @DGatzby. It’ll get warm but my concern is it hitting under load/shifts. The back of the pipe going towards fire wall was actually touching - that problem has been solved
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
