Thread Starter
- #1061
- 1,487
- 2,487
- 162
- Ottawa
- Non-US
- Canada
- 2019 Challenger HC Widebody
Thread Starter
With a huge budget you can do whatever you want, twins, pro charge, etc and your thousands in to it. For like $700 I put a pulley on mine and make 16-17psi and can run 9s. Obviously I had to do injectors, pcm, and tune, but you'd have the same (or more) with the other setups. Cam? $$$$ in this car and good luck with tuning that nightmare.
Hellcats are already very potent as is and with minimal upgrades become street/strip weapons. There are proven combos. If you want to be a trend setter (read R&D customer) then be ready for what that means. Been there done that and have the check stubs that go with it. On the Hellcat I want KISS.
I do agree that I wouldn't personally spin the blower faster than I am now. If I need "more" at some point porting would be next but after the early failures I'm gonna sit that out and see how these hold up long term. I don't want headaches and the porting is pretty expensive as well. I bet you could almost buy a 3.0L IHI for what the porting service costs and you'd be ahead.
I've already met my goals for the car. Had I not had that engine failure I'd have very little in to it for how it runs. With the upgraded engine I'm better off in the long run but it hit the pocket book more than I really wanted for this car. IF I ever decide I wanna run lower 9s I'll be hunting for a 3.0L IHI blower.
The Procharger test video I posted makes it very clear that a basic F-1A-94 ($3500) head unit is 1200+hp capable out of the box on a 427+ cube engine. A full kit is still less than $8000. That is not cost prohibitive when you can pull off your 2.4L blower sell it and never even consider buying a $700 pulley (which is exceedingly disgusting when you can get a Procharger pulley for $100 or less). The business case speaks for itself especially considering the supporting mods are a constant and cancel themselves out.
I'd be curious to know how many guys are sitting at home reading this and wondering what their rotors look like right now. Bet they have that sickly feeling/taste in the back of their throats from anxiety and self doubt...
