Another spark plug thread
I usually install them dry and torque them to 20 ft lbs. was thinking of using some anti sieze the go around. What do you guys do?
Depends on the plug. The shiny ones are coating that you don't use anti seize like the NGK 2309. I used to run copper autolites in a car years ago and those you do
I use the 2309, gapped them to .021
This will be my 3rd set of them on the car, 4th set of pkugs. I change them every time I have everything apart
