Replace fuel level floater and filters
Thread Starter #61
Perfect fit.
Old on the left, new on the right (white). The old one used to be white. Looks like e85 took all of the tension out of it! Car is fixed 😎 60+ psi at run, and 70+ blipping the throttle. Around 57-60 idling. Drove it around, fired it up/shut it off several times and logged. Calling it good. Hopefully this helps someone else. Thanks again for the suggestion @catdad. Was very lucky only 1 Oreilly had one of them in stock, no other stores
and yes, I got all of the dirt out, tank was all but empty
Thread Starter #62
On the bright side, I can disconnect battery, pull pumps (completely) and drain the tank in 20 minutes or less now 😅
Thread Starter #63
I got the tool for the fuel pump ring. Still need to use jack handle on breaker bar and it pops. Still less stressful than a sledge and screwdriver
Thread Starter #64
If you’re having fuel pressure issues and run e85, check that clip.
going to be saving that part number for future reference
I kept a package of those in my glove box in Go Man Go.
Thread Starter #67
1/2” is hard to find typically, hence why they had 1 in the back they had to unbury. Not something stocked on shelves
Thread Starter #68
Hmm, so which one is #2? So this doesn’t show a CEL, gas light just flashes and “server fuel sensor” message shows on evic
Thread Starter #69
Tell me I replaced the wrong one 😑
Yeah. You did.
Thread Starter #71
If 1 is A and 2 is B...1/A indicates driver and 2/B indicates passenger side according to what I'm reading.
Thread Starter #73
If up is down and forwards is backwards…
Thread Starter #74
I don’t think they sell that one separately anymore either…
Thread Starter #75
Found it. Discontinued part, but found 1. $70+ shipping. The saga continues
Discontinued? What the piss...
Compare the 2 when it comes in. For science.
Makes no sense to discontinue only one side.
Thread Starter #77
It does when they can force you to buy the entire jet pump for 5-800$ lol. I will and will post a pic. They are 100% different
68145782AA By chance?
#79
Perfect fit.
View attachment 134916 View attachment 134917 View attachment 134918 View attachment 134919
Any dirt in there?
Thread Starter #80
No. I’ll confirm it’s the right part when it comes in this week
