Was seeing that too. Look again, there's two sets of torque and HP curves. It's blue/green for the "juice" and blue/red for the gas (I assume) then follow them across the page, they correspond correctly. They dance in your eyes when you first glance I guess, cause I saw it that way too. LOL.
Actually I just saw what's going on. The dyno operator put HP on the left and Torque on the right, normally it's the other way around. Carry on LOL.
This is a great representation of how much power a degree of timing is worth. Mike told me to use 15hp as a rule of thumb and in this case it's about 13.6 so pretty close.
My 93 tune has quite a bit less than 14 degrees of timing. I have my knock sensors pretty much stock setting and I bumped my timing until I saw a degree of STKR then backed it off one degree. I don't run any boost additives with 93. On my alcohol timing map I've added about 6 degrees over what the 93 table has and went as high as 8 degrees and had ZERO STKR but backed it down a tick for the street. Mike kinda made a point with me, why lean on the motor for the street, save that for the track.
