Dodge Horsepower Challenge
So 35 possible ansewers is it then ?
I'm guessing they will update later in the day.
There's also tommorow?
Pottstown
2013 Dodge Challenger
I hope so. Like a number of you guys, I have an answer that's very close, but not exact. I'm hoping that "none of the above" choice is eliminated.
Illegal_Demon
Open Space
Im in same boat...its close but not exact....
if its none of the above that's BULLSHAT....and shame on Dodge...
if u want to have that as the answer.....dont give another choice "so close"....
Ok.....for those that have answered this week's question so far.....
A. If you got the answer wrong, did you get a definite indication that you got it wrong?
B. If you answered correctly, did you get an answer other than this generic answer that others have said they got?
So I entered in today's hashtag and it says "You've reached your maximum entries for this code".
Did anyone else run into this ?
Did you already submit your answer to the question?
You can only submit 1 hashtag per day.
If so, then you can't answer the question more than once, and you can't submit new hashtags after you have submitted the answer to the question.
If you put in all 5 correct hashtags, before you answer the question this week, then it would knock you down to 10 possible answers for the question.
OLDBAYCRAB
Middle River
Same here. Guess there is a limit on how many times a hashtag can be used. :unsure::unsure::unsure:
OLDBAYCRAB
Middle River
I played with weight variables using the weights I found online, but settled on the Dodge weight. The variation was small, and my calculation is within <1% of an answer I've been watching. I gonna pull the trigger after I run the calcs one last time as a sanity check.
I should've paid more attention in math class....
Those were the days when ADD (attention deficit disorder) was the problem... :confused::confused::confused:
Then EDD (erection deficit disorder) was the problem....:(:(:(
Now the Horsepower Challenge is the problem...:unsure::unsure::unsure:
Hope I do better with the Challenge problem than I did with the other problems....:LOL::LOL::LOL:
I still haven't found a new/valid hashtag for today... The one I did find for today as we know has already been used.
:mad:
:mad:
Deeper into the twitter.... go you must.....don't feel so blue
Pottstown
I did not answer the question yet and had only entered four hashtags total (Tue-Fri) and when entering today's, received that message.
Today's hashtag is not the same one as yesterdays. There is a new one for today. Look again you must......may the force be with you.
Two found, both previously used
...then you're not blue enough yet.......deeper.....
Pottstown
I guess I'm missing something here. I entered the (4) hashtags as they appeared each day, all week, the last being "into the blue I went". Today's hashtag was posted on Twitter 9 hours ago and when I went to enter that one, the Dodge site acted like I had used it already. Common Core not withstanding, I don't believe 4 = 5.
OLDBAYCRAB
Middle River
:mad:
Try #HEMI :whistle:
Lilschmied
Nowhereville
Interesting that you guys see an answer that's close, I've done the math multiple times and I don't see anything in the ballpark... must need more caffeine :coffee:
32097hp but I failed algebra once
OLDBAYCRAB
Middle River
<<<<<< I bet they're here looking for a struggling family man who could use a new car... that would be excellent marketing. :cool:
In that case, here's the latest photo of me and the family... sure could use a new car... :cry::cry::cry::cry:
Pottstown
