Seems consistent with what I posted above:
https://www.hellcatforum.org/threads/other-forced-induction-options.5005/post-51717
Yes, you can do that to a stock blower - but should you? I'd suggest not, and have, the reality is to stop thinking about "boost" and start thinking about mass air flow. Why spin the blower faster than needed when you can lessen the restriction with other modifications that don't impinge on a mechanical part and impart more stress and heat into everything? Change the way you approach the problem: use different forced induction options, improve the air flow efficiency into the factory supercharger (port it, change the snout, etc), port the heads, add lift and duration to the cam, improve the intercooler efficiency and thermal exchange rate, insulate around the motor...
One of the key factors which I don't believe was disclosed or covered in the M2F video is the brand/type of blower pulley he was running. We know that the factory pulley is a Litens clutch pulley, and that had to be put there for a reason. I surmize it is to protect against the rotors against going out of time (as mentioned by Jokerz) when you've got a Dbag smacking in and out of the throttle all day long at load. Put a solid pulley in there and you lose the cushion. No good. Sure lots of folks may just drive a solid pullied car well enough to avoid the prospective damage - but with 40,000 HCs produced how can you risk it as an OEM?
