Sign Up! To view all forums and unlock additional cool features
Appreciated. And I looked it up. I see what it is. You crimp the wire into the existing wire on one end. On the other end there is a plug which allows for the fuse to be pressed into both the boot and fuse box. A fuse with connectors on both sides.
got her back today. took a fifteen-minute drive to the biosphere 2 and back to my house. 30 minutes in 100-degree weather. i got on her three quarters of the pedal twice. the highest iat temperatures I saw was 139 with 122 as the iat coolant temperature. In a few hours I will check the coolant level in the trunk. if a little low i will add some water so there is no cavitation.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
